Hole cutters for hand drill
07-28-2019, (Subject: Hole cutters for hand drill )
First time I saw this kit at a local shop and I wanted it right away, it makes holes through thick metal very easily without any difficulty and dulled drills. It took a day of searching cause I didn't ask its name so I hope this post will save smbd time
https://www.amazon.com/gp/product/B01KKO...uage=en_US
 Thanks given by: marek4792 , Volvo8873 , Waterloo
RE: Hole cutters for hand drill
nice find. thanks for sharing.
Added to my Amazon too buy list... Thank you!
Added to mine also! Thanks! I was starting to look into buying a real good drill bit set for work.
I just had to drill through steel and alluminum as the pivot bolts on my Ali arc had rounded. I spent hundreds on all sorts of drill bits and step bits and in the end it was the mighty steel hole saw from home depot that made it work!!! hours left side, 5 minutes right once I figured it out!!!
