Adaptive Cruise Control Fault
07-28-2019, (Subject: Adaptive Cruise Control Fault )
2016 KW T680 CM2350
I'm getting a lot of "Adaptive cruise control fault!" engine light; can anyone point me in the right direction how to disabled it in the ECM and ABS systems (Bendixshit radar)?
I try to worked it out with Acom software, aliment of the radar is useless and I'm tire of dealing with all that, I have a bigger fish to fry with the market right now that worry about this stupid system.
if anyone is interesting these are the codes a got:
3845 , 0784, 3843 all inactive ....
The problem of all this crap is that disable my cruise control but what is more important affect my ELD device
Unfortunately my truck was a used truck equipped with Windman system.
Any help will be appreciate.
RE: Adaptive Cruise Control Fault
(07-28-2019 )OTR48 Wrote:  2016 KW T680 CM2350
Take it to the dealer and have them hook up the computer to tell you what it is. I had the same issues, it was my compass. I didn't even know I had one. CanBus systems, a real nightmare. The dealer can sort it out and at least tell you where to start. Otherwise, you will be chasing ghosts and eating time. Trust me.
I was about to put it in a Dealer, it's very frustrate to take it to a dealer every 4-6 month for the same crap. I'm hoping to learn how to fix it or just kill it; I call Bendix several times but as you said it's a goose chase.
Thank you.
Adaptive cruise can be easily disabled with Insite.
(07-28-2019 )Signature620 Wrote:  Adaptive cruise can be easily disabled with Insite.
I have inline 5 with insite software and I try to look how retroactive ACB system but I'm a greenhorn still.
Just an O/O trying to learn how to fix my own truck.
Thank you.
07-29-2019, (Subject: Adaptive Cruise Control Fault )
Should be in features/parameters section of insite just expand every section that pertains to ABS or cruise control and you should find it.
(07-29-2019 )Lonestar10 Wrote:  Should be in features/parameters section of insite just expand every section that pertains to ABS or cruise control and you should find it.
I will give it a try.
Thank you.
08-04-2019, (Subject: Adaptive Cruise Control Fault )
Issue has been resolve !
Thank you for your help.
06-16-2020, (Subject: Adaptive Cruise Control Fault )
Can you please tell how you solved the problem.
My t680 just gave the adaptive cruise control fault I was on the road fine, just when I try to put on the cruise control the fault showed with service flashing also plus abs skid sign.
