Cm2350 no power
08-06-2019, (Subject: Cm2350 no power )
Post: #19
RE: Cm2350 no power
30-35psi is also the max you want on a 2350 if it's not making the power is supposed to in that range then something is either wrong with the engine or wrong with the tuning.
Post: #20
RE: Cm2350 no power
(08-06-2019 )Lonestar10 Wrote:  ....30-35psi is also the max you want on a 2350....
^THIS
Ya beat me to it Lonestar lol
Post: #21
RE: Cm2350 no power
*Snickers in his dark corner*
Post: #22
RE: Cm2350 no power
(08-06-2019 )Tattoo76 Wrote:
(08-05-2019 )trucklogger2 Wrote:  Is it a derate or just sluggish? Low boost? I would keep it simple at first and check seal on fuel/water separator ( maybe even multiple times if no change) then check charge air system.
I would suspect rail press Gauge if derate or injector maybe?
Just ideas there.
Not derate I'm positive of that, it pulls fine until I start pulling some hills then fall on its face. I have to drop some times down to 10th in PA and WV pulling tanker, 18sp 550 hp 3.42 rears
I would definitely try another fuel pressure sensor or press relief valve . Or try that hill again and monitor insite at the same time to try and pinpoint problem.
User's Signature: 36-25-34
