2013 ISX 15 Fault Code 3165
08-25-2019, (Subject: 2013 ISX 15 Fault Code 3165 )
RE: 2013 ISX 15 Fault Code 3165
(08-25-2019 )Rawze Wrote:
(08-25-2019 )kozakvod Wrote:  Considering check engine light is off and fault is not active, do you think I can make it in or is it most likely to just come back before I get there?
re-read my post(s) above, i think I was still typing it in when you replied.
without insute, you are better off not chancing it. - With insite, at least you can reset the derate every 200 miles or so if you got into real trouble. Without it, you are at the mercy of the rip-you-off network of nitwits.
I guess at this point I have no option but to to dealer in the morning.
What if I kept it 55 and under? Or would that even matter at this point?
Or any other suggestion to limp me home?
(08-25-2019 )kozakvod Wrote:  Or any other suggestion to limp me home?
If you can come to PJ in Lubbok we can run diagnostic.
That’s a great offer thank you. Now can I actually get there?
How far are you?
How far are you?
Las Cruces
Hard to say. And what the engine model do you have? 2250 -2350 -X-15?
I will be here available until tomorrow 1pm then have appointment time. don't know about evening yet.
2013 isx15 cm2350
(08-25-2019 )kozakvod Wrote:  2013 isx15 cm2350
2350 is OK because I don't have soft for X-15
