Insite for CM2250 or CM2350
10-26-2019, (Subject: Insite for CM2250 or CM2350 )
RE: Insite for CM2250 or CM2350
(10-26-2019 )Waterloo Wrote:
(10-26-2019 )GreenBean Wrote:
(09-12-2019 )tree98 Wrote:  Most guys on here are using insite 7.6.2 with an inline 5 or 6 adapter. You can get the Chinese version from ebay.
https://rover.ebay.com/rover/0/0/0?mpre=...4393615601
Might be cheaper ones to, this is just the first one I came across.
Does this program require a password or registration through a Cummins Dealer? Monthly subscription fee?
You should be good to go with the eBay kit, everything should be there for you to operate it out of the box without fees.
ya well iv got stil . but never got it downloaded...…..; so after a year I went to cumm at least it works
User's Signature: Just my 2 cents + -
