isx black smoke, fuel knock, engine year 2009 running rough
09-19-2019, (Subject: isx black smoke, fuel knock, engine year 2009 running rough )
RE: isx black smoke, fuel knock, engine year 2009 running rough
Sounds like a slipped cam gear, I had that once before where it showed no codes but had the same symptoms you have. There was no locktite on the nose. Someone had replaced both cams a couple weeks prior to me getting it and had done a crappy job of it. Was good after I redid it.
 Thanks given by: Andre_The_Giant
08-12-2020, (Subject: isx black smoke, fuel knock, engine year 2009 running rough )
sorry its been so long but wanted to say after pulling off exhaust manifold could see valve not opening, bad cam shaft. do not recommend using after market it lasted about 9 months
