I don't want insite to update.
06-13-2016, (Subject: I don't want insite to update. )
7.6.2
locked me out and wanted me to update to newer version.... I don't want to.
How to I keep this from happening?
RE: I don't want insite to update.
Unilever fixed mine via TeamViewer... It had me stumped when it did it to me.
There should be a check box in preferences or tools drop down menu.
You need to disable network connection so it can't access the web.
Making sure it doesnt connect makes sense but I hadn't even gotten into the program yet.
Is there anything you need to do.... like changing the date and time on your Windows clock or only letting windows 7 update to a certain update?
Good chance there was a problem with the install so I'll be trying again in a day or 2.
08-25-2016, (Subject: I don't want insite to update. )
I can't find that drop down. Can I just uninstall the updater?
User's Signature: I don't know sh!t from shinola!
