Insite..
10-16-2019, (Subject: Insite.. )
Insite..
Do I have to have insite put on my truck after replacing the dose injector and the turbo? Doing them both at the same time....
RE: Insite..
You did not mention what make/model engine or truck. For a 2007 (CM871) or newer ISX ...
for the doser injector, no .. but for the turbo, yes. It needs re-calibrating for a proper install. It is mentioned in this video...
10-17-2019, (Subject: Insite.. )
RE: Insite..
I have a 2013 Peterbilt with Cummins isx 3719. It has a low howling sound on the right side and I saw your video about turbos making that noise. And since I have the turbo and dose injector already, I was going to replace both of them.
RE: Insite..
But....the actuator is already on the new turbo. I had a motor blow and I took off the turbo, actuator and doser injector since they were only 4 months old. So I took them off as one big section. Does that matter since I dont have to remove the actuator?
RE: Insite..
It needs calibration because the computer doesn’t know where the position is until in runs open and closed fully then the computer rememberers what position it is in.
RE: Insite..
Gotcha....greatly appreciated chief. Will I be able to drive it to a dealership after I replace it. Or do I need to do it at the same time?
RE: Insite..
I’m not sure. It will probably depend on how far off the new one is from the old one position wise.
RE: Insite..
https://youtu.be/k2j1vnAtbvI ...does she sound ok to you?
RE: Insite..
Get it calibrated. Don’t chicken shi#t your truck over a couple bucks
