Coolant leak |
10-19-2019, (Subject: Coolant leak ) Post: #10 | |||
RE: Coolant leak Well Thx Rawze for reminding me I don't want to be dependent on these crooked shops! I got out there this morning in the rain and found 2 water leaks! I've still got to get a new clamp and gasket for rear of egr cooler that is not sealing back up but for right now coolant pressure is holding! I'm gonna replace imap and delpta p sensor also today, my 2350 is different than cummins your video showed egr lineup on, so any advice on what else I should do to egr system? Thx | |||
10-19-2019, (Subject: Coolant leak ) Post: #11 | |||
RE: Coolant leak Tune up, not line up | |||
10-19-2019, (Subject: Coolant leak ) Post: #12 | |||
RE: Coolant leak (10-19-2019 )tree98 Wrote: Ask and you shall receive https://youtu.be/tNmQnAJzmVoThx | |||
10-19-2019, (Subject: Coolant leak ) Post: #13 | |||
RE: Coolant leak You also need to go to quickserve.com and register your engine serial number(you'll find it on the valve cover..ESN) its FREE. https://quickserve.cummins.com/info/index.html Once you do that you can look up parts and service procedures for your exact engine. Although Rawze's method for testing an EGR cooler is better than the method Cummins wants you to use. Your engine is a little different than the one in that video but the principal is the same. User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
10-19-2019, (Subject: Coolant leak ) Post: #14 | |||
RE: Coolant leak (10-19-2019 )tree98 Wrote: You also need to go to quickserve.com and register your engine serial number(you'll find it on the valve cover..ESN) its FREE. Once you do that you can look up parts and service procedures for your exact engine. Although Rawze's method for testing an EGR cooler is better than the method Cummins wants you to use. Your engine is a little different than the one in that video but the principal is the same. Thx I will definitely do that! | |||
10-19-2019, (Subject: Coolant leak ) Post: #15 | |||
RE: Coolant leak Ok I know have a new clamp and gasket for back of egr cooler, is there anything special about this gasket when putting back together? | |||
10-19-2019, (Subject: Coolant leak ) Post: #16 | |||
RE: Coolant leak Seems like success, new clamp and gasket on EGR cooler worked aloft better with new parts! Replaced both upper radiator hoses and pumped back up to 20psi waiting to see if it holds now. | |||
10-20-2019, (Subject: Coolant leak ) Post: #17 | |||
RE: Coolant leak What are you using to pressurize the coolant system? And that is needed to connect to a T680? I’m looking to test my system | |||
10-20-2019, (Subject: Coolant leak ) Post: #18 | |||
RE: Coolant leak (10-20-2019 )Zondo956 Wrote: What are you using to pressurize the coolant system? And that is needed to connect to a T680? I’m looking to test my system I use this kit... https://amzn.to/35PdSEA A lot of stuff mentioned on this forum can be found on my amazon page... https://www.amazon.com/shop/rawzescollection User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
