What would you have done differently?? |
01-07-2020, (Subject: What would you have done differently?? ) Post: #109 | |||
RE: What would you have done differently?? Do you own that trailer? Id get another 10% if i owned the trailer but we use so many different pieces that its almost not worth it. I dont mind the lighter stuff, 4 to 5 mpg is alot better than 1.x 4.10 gears never get decent fuel mileage. Im picking up a communication building thursday, 95,000 lbs, 12' and 13'9" tall. Probably gross 140,000 ish. Going from Duffield va to Sandston va. Only pays $2600 but should be 400 miles loaded. Its a bit of deadhead but still not terrible for a 2 day load. No escorts either. Going on a 4 axle step deck, they are really easy to load, sometimes you dont even need chains, just binders to the trailer. | |||
01-07-2020, (Subject: What would you have done differently?? ) Post: #110 | |||
RE: What would you have done differently?? (01-07-2020 )hkerekes Wrote: I dont mind the lighter stuff, 4 to 5 mpg is alot better than 1.x This is horse $h!t! I can get 4.5 mpg at 180,000lbs! I guess my 4.10's on 11R22.5's must be holding me back:waaaht: User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
01-07-2020, (Subject: What would you have done differently?? ) Post: #111 | |||
RE: What would you have done differently?? (01-07-2020 )hkerekes Wrote: Do you own that trailer? Id get another 10% if i owned the trailer but we use so many different pieces that its almost not worth it. I would not get out of bed for that load... Are you serious? This industry is in the shitter. | |||
01-07-2020, (Subject: What would you have done differently?? ) Post: #112 | |||
RE: What would you have done differently?? I like seeing the different kinds of work every one gets into. Love the heavy and OD guys chiming in. But along with your "mine's bigger than yours" can you help some of the topic conversation and maybe explain how and why you secured the load or what you may have done differently with it? There's an entire Bragging channel on the site that we can start a show and tell with load size. Ive got the biggest load hauled by far. (A 150lb 2'x2' gas metering head hauled 1200 miles for $2.10/mile and exclusive trailer rights on my 51' stepdeck. Man I had to keep a close watch on that one) This one is kind of for helping guys in the open air freight world learn a little bit so we can make it a tad safer out there. | |||
01-07-2020, (Subject: What would you have done differently?? ) Post: #113 | |||
RE: What would you have done differently?? Sounds like an ameron load that has meter hauled 2 meters this summer User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
01-07-2020, (Subject: What would you have done differently?? ) Post: #114 | |||
RE: What would you have done differently?? (01-07-2020 )Hammerhead Wrote:(01-07-2020 )hkerekes Wrote: I dont mind the lighter stuff, 4 to 5 mpg is alot better than 1.x Im not sure if your serious or not. | |||
01-07-2020, (Subject: What would you have done differently?? ) Post: #115 | |||
RE: What would you have done differently?? (01-07-2020 )Waterloo Wrote: I would not get out of bed for that load... Are you serious? This industry is in the shitter. Would you rather stay at home? Im not happy about it but $2200 after fuel is better than $0 for less than 2 days work and maybe 30 minutes of load securement and no escorts to worry about. | |||
01-07-2020, (Subject: What would you have done differently?? ) Post: #116 | |||
RE: What would you have done differently?? (01-07-2020 )Chamberpains Wrote: I like seeing the different kinds of work every one gets into. Love the heavy and OD guys chiming in. But along with your "mine's bigger than yours" can you help some of the topic conversation and maybe explain how and why you secured the load or what you may have done differently with it? There's an entire Bragging channel on the site that we can start a show and tell with load size. Ive got the biggest load hauled by far. (A 150lb 2'x2' gas metering head hauled 1200 miles for $2.10/mile and exclusive trailer rights on my 51' stepdeck. Man I had to keep a close watch on that one) This one is kind of for helping guys in the open air freight world learn a little bit so we can make it a tad safer out there. I posted pics of the securement, why dont you comment what you would have done different. | |||
01-07-2020, (Subject: What would you have done differently?? ) Post: #117 | |||
RE: What would you have done differently?? (01-07-2020 )hkerekes Wrote:(01-07-2020 )Hammerhead Wrote:(01-07-2020 )hkerekes Wrote: ... maybe he will chime back in and explain.. but even I know that your rear ends are not your problem.. quite the opposite. -- If you think for one moment that some (already) decent gearing is your troubles, then you are gravely mistaken.. --- it it either your truck, your engine, and/or what you do, or your right foot that is the problem. 4.10 gears are excellent for moving the heavier stuff, helps keep the engine rpm's up (greatly extends engine life when heavy all the time), and gives you the ability to have full power output when needed of the engine .. the rest of "it sucks more fuel" simply comes down to your right foot, or something else, and how much you abuse,.. or respect that added ability to get stuff moving when needed because you ARE geared correctly for what you are doing, it seems... and HAS THE ADVANTAGE over the other idiot-spec's trucks that are geared too tall, that can't get out of their own way. These newer trucks that are geared way too tall,.. they get better fuel mileage, directly at the expense of engine life. Not because the gearing is any better,.. it is much WORSE... but because when an engine is running in low rpm ranges (because it is geared too tall),.. it is COMPLETELY UNABLE TO MAKE FULL POWER OUTPUT! - and therefore is exactly the equivalent as someone who is geared lower, but stays off the pedal, and only allow their engine to only make that limited power as well. -- it is the mega-fleets latest bean-counter way of making the engine limit its power output production, while the idiot driver holds the pedal all they way to the floor all day long. I.E.> gear it too tall, so that full engine power cannot be produce,. saving fuel at the direct expense of engine life -- OR,.. Gear it right (like in your 4.10's) and learn to control/limit your engine's power just like the "geared too tall trucks" and get the same, or better fuel saving by learning to use your right foot better, and driving by your boost and pyro gauges. The choice is yours,.. but it is NOT YOUR REAR END you should be blaming, not one bit. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
