cm570 engine brake faultcodes and weak brake
10-22-2019, (Subject: cm570 engine brake faultcodes and weak brake )
since i have changed my engine brake solenoids from the 2wire to one wire solenoid my brake has become weak and check engine light comes on i left the ground side disconnected ....its it a must that i use 2 wire solenoids or must i connected the ground side.. i cannnot geet the 2 wire solenoids easliy
