Has anyone heard about this shop or store before
11-16-2019, (Subject: Has anyone heard about this shop or store before )
So i am just googling around and i find this store.
{name removed}
Havent heard of them but im wondering if anyone here has heard of them before.
RE: Has anyone heard about this shop or store before
aftermarket heads, no monotherm pistons that I can see. I don't think I would trust their stuff.
aftermarket internals and heads, + places that sell them are not recommended here.
(11-16-2019 )Rawze Wrote:  aftermarket internals and heads, + places that sell them are not recommended here.
I apologize, didn't mean anything buy it.
There is a place that Mr. hag uses to re-buching and inspection of wrist pins/rods. They do them well, I have even had them done there with a couple people when helping them here. -- But I don't think it is the guys u mentioned. - The shop that Hag uses also re-builds heads and the like, but even hag does not use them for head, etc. . - Too many times there was bad luck, always ends in head needing replaced in 200-300k miles.
He only uses the place for wrist pin bushings and rod inspections.
someone would have to PM him if they want the name of the place.
(11-16-2019 )Rawze Wrote:  There is a place that Mr. hag uses to re-buching and inspection of wrist pins/rods. They do them well, I have even had them done there with a couple people when helping them here. -- But I don't think it is the guys u mentioned. - The shop that Hag uses also re-builds heads and the like, but even hag does not use them for head, etc. . - Too many times there was bad luck, always ends in head needing replaced in 200-300k miles.
its good to know, their is a local reman shop in Ga close to you guys. if you guys use them then they must be worth the repeat business.
They are, but Like I said,.. only for wrist pins and connecting rods on the ISX. - Mr. Hag would know more.
 Thanks given by: Evotrucker
