| using a hand held fuel guage |
| 11-27-2019, (Subject: using a hand held fuel guage ) Post: #1 | |||
| using a hand held fuel guage I have a cm870 and checking the fuel pressure at idle it jumps from 180 to 280 very fast, cant take a reading. If I rev the rpms to 1500 and hold it there, it will hold steady at 260. Is this normal? | |||
| 11-27-2019, (Subject: using a hand held fuel guage ) Post: #2 | |||
| RE: using a hand held fuel guage Try a different gauge and see if it does the same thing, could be a faulty gauge. I think 260 is within spec, maybe at the lower end of the spectrum though. | |||
| 11-27-2019, (Subject: using a hand held fuel guage ) Post: #3 | |||
| RE: using a hand held fuel guage its not the gauge, the whole line is vibrating at idle. | |||
| 11-27-2019, (Subject: using a hand held fuel guage ) Post: #4 | |||
| RE: using a hand held fuel guage How old are the fuel lines? User's Signature: I have no idea what I’m doing and probably need supervising | |||
| 11-27-2019, (Subject: using a hand held fuel guage ) Post: #5 | |||
| RE: using a hand held fuel guage 2005 volvo and lines are original but not seeing bubles or fluctuation in the davco water separator. | |||
| 12-01-2019, (Subject: using a hand held fuel guage ) Post: #6 | |||
| RE: using a hand held fuel guage I changed the gear pump with another used one I had and seems to have a 10 to 15 psi more. It stays up at 275psi at 1500rpm. Going to run it this week see how it does. | |||
