Fuel pressure and restriction test
12-07-2019, (Subject: Fuel pressure and restriction test )
Post: #19
RE: Fuel pressure and restriction test
well you didnt have vacuum if you took the reading while the elec pump was running it puts out about 10-20psi
Post: #20
Cummins didn’t bring that up in the instructions
I guess they assumed idiots weren’t going to be attempting them
Post: #21
best way to do any test is start engine let run for a bit so everythings all evened out then do tests that require engine running.
 Thanks given by: DDlighttruck
12-08-2019, (Subject: Fuel pressure and restriction test )
Post: #22
(12-07-2019 )Lonestar10 Wrote:  best way to do any test is start engine let run for a bit so everythings all evened out then do tests that require engine running.
The truck was warm by the time I got to the shop. I let it run for 20 minutes or so, then tried it again today. It’s still showing pressure there, 3-4 psi
So I don’t know. Maybe another shop has one I can use to double check what I’m seeing
