| Trans mission gauge |
| 11-29-2019, (Subject: Trans mission gauge ) Post: #1 | |||
| Trans mission gauge Hi, It's says online the the tranmission guage is supposed to read between 175° to 225°F. After driving my prostar nearly 60 miles it crept up to just around 115*F. Does the gauge need replaced, and until then how may I monitor the temp? User's Signature: We're a full grid off. | |||
| 11-29-2019, (Subject: Trans mission gauge ) Post: #2 | |||
| RE: Trans mission gauge Was this bobtail or with a trailer? User's Signature: I have no idea what I’m doing and probably need supervising | |||
| 11-29-2019, (Subject: Trans mission gauge ) Post: #3 | |||
| RE: Trans mission gauge This time of year, that sounds normal to me... It is cold out everywhere, 150 under a load is normal right about now, unless you are up in the mountains pulling heavy. Then, 200+ is not out of line. I think you are fine, especially only going 60 miles, again, sounds normal to me. | |||
| 11-29-2019, (Subject: Trans mission gauge ) Post: #4 | |||
| RE: Trans mission gauge I'm bob tailing. Btw, while we are on top of the board, the place where I got the truck from used synthetic mobil delvax extreme 10w-30... It's a Cummins engine and rotella T needs to be used... What do I do now, go back to rotella T after 12,000 miles or stick with what's in the engine now? User's Signature: We're a full grid off. | |||
| 11-29-2019, (Subject: Trans mission gauge ) Post: #5 | |||
| RE: Trans mission gauge Bobtailing you’re barely working the tranny. 115 degrees is fine Generally you want lower oil temps as a goal, oil (as far as I understand it) breaks down faster the hotter it is. User's Signature: I have no idea what I’m doing and probably need supervising | |||
| 11-29-2019, (Subject: Trans mission gauge ) Post: #6 | |||
| RE: Trans mission gauge run the syn out switch to your choice of oil + gallon of gear lube call it a day. User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 11-30-2019, (Subject: Trans mission gauge ) Post: #7 | |||
| RE: Trans mission gauge Everyone I have seen run full synthetic on an ISX has had valve cam issues. - this is because either they use 10-30 (too damn thin!) or they extend oil change intervals (+ bypass filter system) like a fool and it eventually repeatedly wipes out the cams. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
