Overshot's Blog
08-23-2016, (Subject: Overshot's Blog )
Post: #19
RE: Overshot's Blog
Imo is not a coolant leak inside the engine.....you must show boron,sodium and potassium...yes all three for a coolant in oil
Mr lee you are using delo15w-40 this oil has the highest 557ppm boron count since new ...absolute highest of all ((rotela 42ppm, delvac 73))
Yes boron is in most antifreeze but is used in the oils as additive
Delo has <5 ppm counts of potassium in the oil but is an additive in gear oil too, yours is not very high
Delo has <5 ppm of sodium in oil already
Are using gear oil????
Aluminum is found in Pistons,bearings and pumps ...so maybe your coolant pump is going downhill!!!!
Dell has 3ppm aluminum already....highest
And the TBN is the lowest of all big 3 oil ...only 8.86....((((delvac 11.0, rotela 10.6))
The TBN is not supposed to be left to drop more Than 1/2 of it since new before changing oil
So theoretically u must change the oil sooner than 17k miles...
Post: #20
RE: Overshot's Blog
T680 I use delo
08-24-2016, (Subject: Overshot's Blog )
Post: #21
RE: Overshot's Blog
T680How can the coolant pump be a problem. Oil is in no way around the water pump for it is external pump belt driven.... Unlike cat or detroit or even volvo.
Post: #22
RE: Overshot's Blog
That îs right mr.hagg.....
Post: #23
RE: Overshot's Blog
Mine just came in.....wish I know how to post it
Alum 0
Iron 2
Cooper 0
Lead 0
Molly 17. Boron 105 magnesium 85. All good
Lots of zinc,phosphor,calcium. Very good
Tbn. 6.17.
No sodium low potassium
1gal of gear oil. Rottela 15-40
Post: #24
RE: Overshot's Blog
(08-24-2016 )T680 Wrote:  Mine just came in.....wish I know how to post it
Alum 0
Iron 2
Cooper 0
Lead 0
Tbn. 6.17.
Great results. How many miles on this oil? What are zinc readings?
Post: #25
RE: Overshot's Blog
Oil 10 k
Engine 301 k
Zinc 1287 soot<.1,
Ceck ((abc of oil analysis, at http://www.thedieselstop.com
They say that for coolant in oil must have boron,sodium and potassium high readings
For bearing problems must see cooper,tin and lead high
Post: #26
RE: Overshot's Blog
This is mine 60000 miles on Inframe, oil has 15000 miles. Have a look and let me know if you see any problems
./uploads/201608/post_225_1472092339_00318d03cac458fcc862ac7325835a1a.jpeg
08-25-2016, (Subject: Overshot's Blog )
Post: #27
RE: Overshot's Blog
(08-24-2016 )8042 Wrote:  This is mine 60000 miles on Inframe, oil has 15000 miles. Have a look and let me know if you see any problems
Looks good.
Solubles, is that soot?
Is your truck still mandated?
