2015 cm2350 tuning??
12-06-2019, (Subject: 2015 cm2350 tuning?? )
Hey y’all iv got a 2016 w900 with a 2015 cm2350, currently the truck gets horrible fuel economy has no power and just simply unreliable. I’m a one truck owner operator and just can’t afford
This type of mpg and down time. I’m looking for a good safe tune geared towards economy and reliability. Ps I have done a egr tune up on the truck. Thank you for any help it is greatly appreciated.
Mike H. Central Illinois.
RE: 2015 cm2350 tuning??
Send a PM to Unilevers or mommaburt or both
(12-06-2019 )tree98 Wrote:  Send a PM to Unilevers or mommaburt or both
Will do thank you
You'll need an inline adapter https://rover.ebay.com/rover/0/0/0?mpre=...3742287676
And a laptop
(12-06-2019 )tree98 Wrote:  You'll need an inline adapter https://rover.ebay.com/rover/0/0/0?mpre=...3742287676
And a laptop
Ok I will go ahead and order one, thank you for the quick response!
If neither of these guys is Available, I can help you as well,
Have you ran the overhead? Inspected the cam and lobes?
Fuel pump been looked at? Injector leak down test? Cac. Pressure tested?
(12-06-2019 )Icon900 Wrote:  Hey y’all iv got a 2016 w900 with a 2015 cm2350, currently the truck gets horrible fuel economy has no power and just simply unreliable.
== neglected severely, possible abused, it sounds like to me.
These red cry-babies are good to ya if you keep after them and treat them right. If you waiting all the time for the CEL lights and problems to set in before keeping after anything,.. you have lost the game.
 Thanks given by: Pd6cas2
