Cm2250 overhead set
12-16-2019, (Subject: Cm2250 overhead set )
RE: Cm2250 overhead set
I'm just going to stick with my 3/8 torque wrench and doing 15ft lbs. I can hear the click on that atleast. Just gotta figure out the dial indicator on engine brake side note.
12-17-2019, (Subject: Cm2250 overhead set )
its all a right off buy the right tools for the job and call it a day. think i spent about 350 bucks for a Nm dial type torque wrench for injectors (cm871) a regular in lb torque wrench and every other tool needed to do an overhead. and i would do it all over again as everything is just that much easier. also a torque wrench is most accurate in the middle of its torque span so a 100 FT/lb Twrench is most accurate at 50lbs apply that to any torque wrench.
