| cm 2250 intake manifold |
| 02-24-2016, (Subject: cm 2250 intake manifold ) Post: #1 | |||
| HI FOLKS, TODAY I STARTED PERFORMING AN EGR TUNE UP ON MY ENGINE. DURING THE PROCESS OF CLEANING THE INTAKE I DISCOVERED SOME CORROSION ON THE GASKET SURFACE. I DIDN'T SEE ANY EVIDENCE OF IT LEAKING. BUT, I AM SURE THAT IT WILL. SO DO I JUST REPLACE THE INTAKE OR TAKE IT TO A MACHINE SHOP AND GET IT MILLED DOWN? ANY SUGGESTIONS? THANKS | |||
| 02-24-2016, (Subject: cm 2250 intake manifold ) Post: #2 | |||
| RE: cm 2250 intake manifold Yes find some very hard titainum two part epoxy mix it up and fill in spots. Then use flat file to make it perfect. But the best way would be to have it milled down. | |||
| 02-24-2016, (Subject: cm 2250 intake manifold ) Post: #3 | |||
| RE: cm 2250 intake manifold thanks gearhead. i shouldn't have to use the epoxy if I have it milled, right? | |||
| 02-25-2016, (Subject: cm 2250 intake manifold ) Post: #4 | |||
| RE: cm 2250 intake manifold No not if you get it milled it was just a way you could have went with. There is some two part epoxy that guys fix counter bores with. The stuff is so hard they fill counter bore bore with it then after it cures they use counter bore cutter and cut the epoxy. | |||
| 02-26-2016, (Subject: cm 2250 intake manifold ) Post: #5 | |||
| RE: cm 2250 intake manifold Belzona! | |||
| 02-27-2016, (Subject: cm 2250 intake manifold ) Post: #6 | |||
RE: cm 2250 intake manifold (02-25-2016 )gearhead Wrote: No not if you get it milled it was just a way you could have went with. There is some two part epoxy that guys fix counter bores with. The stuff is so hard they fill counter bore bore with it then after it cures they use counter bore cutter and cut the epoxy. That's what I thought you meant. I had it milled. They only had to cut .020 | |||
