Oil Pressure drop
01-01-2020, (Subject: Oil Pressure drop )
Oil Pressure drop
02 CM570
Oil pressure this new year morning drop from 17psi idle to 10 idle , also driving 63mph pressure was 38psi normally. Now 27 psi going 63 mph !
I just replaced main oil filter ‘ no change in pressure, I added a gallon oil and quart of gear lube.
Engine inframed 250k ago , new head, new oil pump !
No power lost or engine codes , truck runs excellent new turbo 2500 miles ago and oil lines to turbo.
RE: Oil Pressure drop
Maybe your oil pump is getting weak.
spun cam bearing?
 Thanks given by: Pd6cas2 , Brock
250k on Cummins oil pump , I will open the top end tomorrow!
Am I damaging engine by running this oil pressure!
(01-01-2020 )Unilevers Wrote:  spun cam bearing?
I don’t hear any new chattering noises from top end , Would I hear metal on metal noise?
(01-01-2020 )Pd6cas2 Wrote:  250k on Cummins oil pump , I will open the top end tomorrow!
To some point. If bearing spun crank or camshaft will be destroyed.
Well you have lost 10psi so something is wrong. I would be scared to drive it like that if it were mine.
I would start by removing valve cover and see what you can see.
(01-01-2020 )Mattman Wrote:  Well you have lost 10psi so something is wrong. I would be scared to drive it like that if it were mine.
I will post pics of top end
How old is your oil pressure sensor?
 Thanks given by: Magard
