Cummins fault code 3539? |
01-05-2020, (Subject: Cummins fault code 3539? ) Post: #1 | |||
Cummins fault code 3539? Any help on this fault code 3539 . I replaced the intake throttle actuator already and this fault code comes on . Any ideas thanks | |||
01-06-2020, (Subject: Cummins fault code 3539? ) Post: #2 | |||
RE: Cummins fault code 3539? Did you remember to plug it back in? Did you somehow damage the plug or wires while you were working on it? User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
01-06-2020, (Subject: Cummins fault code 3539? ) Post: #3 | |||
RE: Cummins fault code 3539? Possible causes of this fault code include: A malfunctioning engine intake air throttle position sensor A short circuit to battery in the engine harness. An open circuit in the engine harness Conditions For Clearing The Fault Code To validate the repair, perform a key cycle, start the engine and let it idle for 1 minute. | |||
