ISX400 Tune
01-14-2020, (Subject: ISX400 Tune )
ISX400 Tune
Hey guys im new here. Bought this Walmart Cascadia with Cummins ISX400ST
Was it designed to handle 500hp? Rear axle ratio is 247
Should I or just leave it as it is. Whats the pros and cons. Is more HP better mpg? Just trying to figure out what's the best tune for this engine. Or its better to leave it as is. Here are few eng pix
Thanks in advance guys
RE: ISX400 Tune
(01-14-2020 )izmail0513 Wrote:  Hey guys im new here. Bought this Walmart Cascadia with Cummins ISX400ST
Spend the money on changing your rears to a better ratio, 2.47 is absolutely horrible. You probably already have liner fretting issues. More horsepower is the last thing you should be concerned with right now.
 Thanks given by: hhow55 , Waterloo
RE: ISX400 Tune
Automatic or manual? If a manual, swap out the gears in the rear end, say something around 3:55 or so. If an auto, sell the truck. Just kidding... Kind of...
What are you planning on hauling? Van, flat, heavy, light? Tanker?
What are you going to do with this truck? You driving it or putting a driver in it?
The HP is not going to help much with that gearing, but I believe the ST can be bumped up to a point.
How many miles on the truck? And you do know about the fuel pumps? That would be the first thing I would do before putting it in service.
Have you looked under the top? Open her up and inspect the cam shaft? You will need to run an overhead too... Actually, there is a laundry list of stuff that you will need to tackle before putting the truck into service.
You will need the Cummins Inline reader with the Insite software, you supply the laptop. I keep mine in the truck, it is like American Express, you do not leave home without the reader and laptop.
Tell us some more on your plans and your mechanical abilities.
 Thanks given by: izmail0513
RE: ISX400 Tune
(01-14-2020 )Waterloo Wrote:  ...
It's a 10spd Manual with 625kmiles and Im going to be hauling dry VAN
Its a 2015 model, that's another question about fuel pump, is it updated on 15 models?
Will be doing overhead adjustment soon as well. Didnt inspect a camshaft or anything internal, just got the truck, no info on the dpf filter and all the sensors too. Just trying to gain as much info as possible since I've had volvo with D13 engine, so this isx is completely new for me. Do i purchase the software on ebay?
RE: ISX400 Tune
(01-14-2020 )tree98 Wrote:  ...
Please explain why is it that bad? If i'm mostly on flat terrain it shouldnt be that bad, as far as i understand
RE: ISX400 Tune
It is bad, because the engine runs at low rpm's, likely around 1250. The rpm's on this engine need to be at 1500 or better to prevent fretted liner's.
RE: ISX400 Tune
Here is the Cummins Inline that most all of us use here...
https://www.ebay.com/itm/Cummins-INLINE-...SwIJlZ9U~7
The gearing and that transmission is a tough nut to crack to keep the rpm's up above that 1500 rpm's, I run mine at 1700 rpms all day long. Try not to drop below 1500 as much as possible, especially when loaded.
The issue you run into when running below 1400 rpm's are the liners, you lug the motor, the liners in time fret, or break loose and damage the head. It is normally the #5 liner. Then you in frame.
When outfits like Walmart order these trucks, they spec them stupidly so that any mouth breather can drive them and return good fuel mileage. They do the least maintenance possible on these units and then sell them off before they fail.
These new trucks are designed with a life expectancy of 500,000 miles, that is why you see so many being sold off with 300,000 miles +/-.
Now, the fuel pump, is it still painted red? If it is, I would rebuild that immediately, as odds are it is the factory original. They have a normal lifespan of roughly 400,000 miles under ideal circumstances. When they fail, if the truck is not shut down immediately, catastrophic engine damage is normal. The metal flows through the oil system, and basically destroys the entire motor. If caught in time, it is still a $10,000 to $15,000 repair.
Me, I would pull the pump and rebuild, that way you know it was done properly.
Then, get under the top, you really need to inspect the cam shaft and lobes. It is rare for these motors to get this far along in life without carbon packing, which leads to cam and lobe damage. Odds are, it has never had the overhead ran. So I would do that the same time I did the fuel pump.
The gearing, when you get some weight on you will be going WTF, as the truck will not get out of its own way with those gears. I would look at some 3:55's or around that ratio for the best performance and fuel economy.
Sounds like the emissions are intact, that is a good thing, it means no one has messed with the ECM. You will need that Cummins reader and software to stay up on that stuff, as it can get very expensive down the road when these systems need maintenance. A shop will empty your wallet, you will need be proactive and keep up on these systems, which means learning how they work and how to repair and maintain them.
I would also visit the Amsoil web site and order their bypass oil filter kit and install that. You will need that to keep the soot down in the oil. Your motor will thank you.
Oil changes, every 12,000 miles or there about, up to 15,000 max on that motor. If there are signs of carbon packing, changing the oil every 3,000 miles may be in order, roughly three to four times, to clean the soot and carbon out of the motor.
There is more, others will chime in...
Oh, you can thank the EPA for all of this...
RE: ISX400 Tune
Thank u. Very informative
RE: ISX400 Tune
Good luck.
