ISX 2350 - Secondary Idle Shutdown
01-24-2020, (Subject: ISX 2350 - Secondary Idle Shutdown )
Is anyone aware of location of a Secondary Idle Shutdown on ISX 2350 -
I have Insite - The Idle Shutdown Parameter is Disabled and even if was Enabled the shutoff time is set at 5 MIN. But even with it disabled the Truck will shut off every 30 Min
RE: ISX 2350 - Secondary Idle Shutdown
What type of vehicle is it? Some manufacturers shut the engine down via their own modules in the dash after extended idling. Take it to the truck dealer or get a hold of their OEM software.
EDIT - 30mins is a long time to idle them - You should absolutely be bumping the idle up with the cruise control/PTO feature .
2015 International Prostar
there are 2 idle shutdowns on 2350's and up. there is the programmable idle shutdown and the is the GHG idle shutdown. Both will need to be disabled to remove idle shutdown completely if they were enabled.
 Thanks given by: JimT
