| CM870 Blue Haze |
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #1 | |||
| CM870 Blue Haze Dads CM870 2007 T-600 "Stock" no tuning. 1.6mil chassis around 200k on overhaul Truck is hazing blue real bad stinks to high heaven. Truck is switching engine modes or something because at one moment it can be running fine then the engine skips a beat you can hear it do something with the turbo then starts to haze real bad then it might skip again and start clearing up just to skip a beat again and haze. for how bad the blue haze smells i think its raw fuel when running insite engine tests it throws random codes but doesnt when driving so far replaced his original actuators metering and timing new engine harness tried a known good ECM its being pin timing checked today any direction to go in? im out on the road so idk if hes listening to me all when i tell him to data log it with insite and see if any sensors are going wonky. User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #2 | |||
| RE: CM870 Blue Haze does it have a boost and pyro gauge installed?-- what are they doing? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #3 | |||
| RE: CM870 Blue Haze He's still running EGR, right? Could be the valve or piping. | |||
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #4 | |||
| RE: CM870 Blue Haze The fact you can“ hear something like the turbo” leads me to think the EGR is sticking. It happend to me.. It would only stick/hang up once in a blue moon. (Even after Physically cleaning it) It took a bunch of insite Egr/turbo tests to finally get it to fail a test, with a solid week of driving around with insite hooked up. User's Signature: I may be cross eyed, but i don’t cross thread | |||
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #5 | |||
| RE: CM870 Blue Haze Yeah still has EGR. The turbo almost sounds like it's chuffing at idle you hear it start to spin up just barely then it drops out then does it again. Has pyro and boost. He said pyro was cooler than normal but boost was still good. User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #6 | |||
| RE: CM870 Blue Haze Based on my recent experience, I'd have to agree that the EGR valve could be the problem. When mine was going the symptoms were lower EGT's (resulting in bad regens), turbo spooling more or less than normal and eventually the valve stuck full open and choked out the engine trying to climb a grade. My situation was probably made worse by old neglected sensors too. User's Signature: "...And as we wind on down the road, Our Shadows taller than our Soul..." | |||
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #7 | |||
| RE: CM870 Blue Haze Turns out he spun a bearing in the cam idler gear knocked both cams out of time User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #8 | |||
| RE: CM870 Blue Haze Interesting find. Did you get any pictures? | |||
| 01-30-2020, (Subject: CM870 Blue Haze ) Post: #9 | |||
| RE: CM870 Blue Haze No I'm on the road him and his mechanic found it. So getting new idler and replacing scissor gear as it damaged that as well the idler had been walking back and forth on the bearing. Got lucky I guess that gear could froze and sent valves in pistons User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
