High idle settings?
02-19-2020, (Subject: High idle settings? )
High idle settings?
This is probably gonna sound like a dumb question to some but bare with me. On my newly acquired 2350 I'm wondering if you can adjust high idle settings? I wouldn't mind having a higher idle selection. Can this be done?
Thanks
RE: High idle settings?
Get insite and adapter
(02-19-2020 )Magard Wrote:  Get insite and adapter
Yep got that. Just got my adapter tonight.
When you get it up and running it’s in the features and parameters
 Thanks given by: sprayerman
You can directly set the desired idle like Magard said under the Features and Parameters. There should also be a setting in there to allow for manual idle adjustment, I think via the cruise + and - buttons, though that might be configurable too. You can even specify the amount of rpm's to scale by each button press. This is useful when you want to see how the engine and oil pressure perform at different rpm's.
02-20-2020, (Subject: High idle settings? )
usualy if you have a cruise on - 900 and 1100 rpm idles if you hold the set button the RPMs will go down and hold resume they go up.
Well I got connected but seem to be locked out of some parameters. Any ideas?
go to options, and Security, and post a pic of what you see while connected to the truck.
Also maybe post a pic of what you think is locked out, that your trying to set.
Look and see if PTO is disable. if so need to enable it and expand it and set max rpms to like 1650 or so then what ever you want set or resume to be the last 2 in that area
 Thanks given by: Rawze , sprayerman
