Boost pressure check engine engine light |
03-03-2020, (Subject: Boost pressure check engine engine light ) Post: #1 | |||
![]() I got a boost pressure check engine light on .. I have a 2011 Peterbilt isx15 2250 with 470800 miles on it.. truck will run good throughout the day and than I’ll have boost problems out of no where.. check engine light comes on and boost pressure valve not hits 15 -19 psi.. and than light comes off and boom back to normal.. any suggestions what it is | |||
03-03-2020, (Subject: Boost pressure check engine engine light ) Post: #2 | |||
RE: Boost pressure check engine engine light Something rattling around in the exhaust somewhere, sometimes restricting and sometimes not ?? Do you have a pyro ? Is it higher than normal when your boost drops? Could be the turbo itself too. Next time it happens pull the exhaust pipe off the turbo and see if boost comes back. You should have a look at the inside's of your turbo too. Any other codes ? | |||
03-03-2020, (Subject: Boost pressure check engine engine light ) Post: #3 | |||
RE: Boost pressure check engine engine light When was the last time you changed your manifold air pressure sensor. | |||
03-03-2020, (Subject: Boost pressure check engine engine light ) Post: #4 | |||
RE: Boost pressure check engine engine light I don’t here anything rattling I’ll pay more attention to that tomorrow, and yes sometimes it restricts and sometimes not, no pyro, ok I’ll check the turbo when it happens again and I don’t have any other codes. | |||
03-03-2020, (Subject: Boost pressure check engine engine light ) Post: #5 | |||
RE: Boost pressure check engine engine light Probably never I bought the truck a month ago but where would that manifold air pressure sensor be? | |||
03-04-2020, (Subject: Boost pressure check engine engine light ) Post: #6 | |||
RE: Boost pressure check engine engine light I just found where it’s located.. | |||
03-04-2020, (Subject: Boost pressure check engine engine light ) Post: #7 | |||
RE: Boost pressure check engine engine light (03-04-2020 )Ballerxl Wrote: I just found where it’s located.. http://rawze.com/forums/showthread.php?t...87#pid1087 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
03-04-2020, (Subject: Boost pressure check engine engine light ) Post: #8 | |||
RE: Boost pressure check engine engine light Thanks rawze I’ll change those out and we’ll see what happens | |||
03-04-2020, (Subject: Boost pressure check engine engine light ) Post: #9 | |||
RE: Boost pressure check engine engine light How do you know the fault is for boost pressure? The symptoms sound like a fault code that applies a derate. | |||
