X15 questions
03-13-2020, (Subject: X15 questions )
X15 questions
If you were looking at a new truck would you get the higher compression performance series or the lower compression efficiency series if you were gona see if uni could put a legal efficiency tune on with say a 500 1750-1850 rating. Which one would achieve the better efficiency with the uni magic.
Spose I'm more or less putting this question towards Unilever if he sees it.
User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s - skateboarder
RE: X15 questions
(03-13-2020 )Lonestar10 Wrote:  If you were looking at a new truck would you get the higher compression performance series or the lower compression efficiency series if you were gona see if uni could put a legal efficiency tune on with say a 500 1750-1850 rating. Which one would achieve the better efficiency with the uni magic.
I would go with lower static compression. Less stress on heads, gaskets and liners. As i understand it with lower compression u can run a little higher advance and a bit more boost.
RE: X15 questions
I could be wrong but I don't think the compression ratio is different by enough to make much difference between the two.
RE: X15 questions
I think I've heard eff 18.5 perf 18.9
RE: X15 questions
If the cams are the same probably not a lot of difference either way.
RE: X15 questions
The 2 versions of x15 are not the same. 500hp and less is considered the economy motor and more is the performance motor. The performance motor has stronger internal parts including the driveline. My brother has a 2018 kw 900 with performance motor at 565 horsepower and he's really happy with it. Do a bit more research before buying and good luck
[/quote]
 Thanks given by: Bahdan , 5022
03-14-2020, (Subject: X15 questions )
RE: X15 questions
(03-13-2020 )Ben50291 Wrote:  ... The performance motor has stronger internal parts including the driveline.
Please do not make statements like that based solely on assumptions or opinions alone (or perhaps re-regurgitated crap off social medai sites). here are the actual differences ...
x15 mid-tier (X15 CM2350 X114B – Efficiency Series. 450hp engine was referenced)...
----overhead cam: 3690406
----pistons: 3691387
----connecting Rods: 3689108
----Block: BB1958-assy (casting 4311621)
----crank: 3691444-assy (3691443 crank w/o tone rings, etc.)
----head: PP10489 (4101454 exhaust valves, 3685996 intake valves )
----injectors: PP10425
x15 big tier (X15 CM2350 X116B - Productivity Series. 605hp engine was referenced) ...
----pistons: 3691713
----Block: BB1950-assy (casting 4311621)
----head: PP10490 (3686661 exhaust valves, 3685996 intake valves )
x15 big-tier (X15 CM2350 X116B - Performance Series. 565hp).
----Block: BB1950-assy.
----crank: 5440758-assy (5440757 crank w/o tone rings, etc.).
What is actually same ...
----Overhead cam =- same
----Connecting rods =- same
----block =- same between the Efficiency and Performance series.
----crank =- same between the Efficiency and Performance series.
----injectors =- same
----Intake valves on head =- same
What is actually different ...
----head =- different (due to different exhaust valves only)
----pistons =- different (due to slightly different compression ratio)
----block =- Slightly shorter and heavier than the one used on the performance/efficency series engines.
----crank =- Slightly shorter and heavier than the one used on the performance/efficency series engines.
 Thanks given by: tree98 , david24 , Waterloo , Mike in NC
RE: X15 questions
Do you think the difference in exhaust valve is size or the amount of heat it can take or both.
RE: X15 questions
605 is productivity series
User's Signature: First and last Cummins
