2013 isx
04-21-2020, (Subject: 2013 isx )
2013 isx
Mt truck has been down 3 weeks repair at dealership with no luck 15,000 in repairs..ive called mr hagg with no luck speaking to someone..does anyone know of a shop thats good with these engines
RE: 2013 isx
Your location?
RE: 2013 isx
Anderson sc
RE: 2013 isx
I jus bought the truck a month ago been down too long ..needing to get it running asap..thanks
RE: 2013 isx
Send a pm to rawze,
RE: 2013 isx
Some history, like what have they done. And what they are saying now. What kind of problem's were you experiencing?
RE: 2013 isx
Ive taped on his name dont see where to pm him..im not very efficient with electronics. Takes me awhile to figure it out
RE: 2013 isx
I can take a picture of repair bill but dont know how to post it..dpf light keeps comming on.truck regening constantly...cleaned dpf and doc.replaced egr cooler. Cleaned fuel doser..replaced imap and dif pres sensors replace turbo and actuator. Replace water pump..now saying its either the scr or doc or the doser pump or doser inj..they want to replace until they fix it..cant afford any more parts changing
RE: 2013 isx
Push, pull, or drag it out of that shop.
Need to get you a laptop computer. Get Cummins insite program off of eBay along with a inline 6 adapter to go between laptop and your trucks diagnostics plug.
