Cummins M11 injectors?
04-28-2020, (Subject: Cummins M11 injectors? )
Hi friends.. M11 injectors can work on ism cm570 Cummins engine?....
04-29-2020, (Subject: Cummins M11 injectors? )
RE: Cummins M11 injectors?
Probably not. Got an engine number for the one they came from and the one you want to put them in?
Get your engine serial off data plate and call cummins tech support or parts dept will tell you .
