Another oil pump shin question
07-11-2016, (Subject: Another oil pump shin question )
My cm2250 has 519047 miles/10693 hrs on it.
Would it be advisable to shim the oil pump?
Current oil psi at operating temp is 35.
40 when cold at idle.
RE: Another oil pump shin question
35 psi at operating temperature at idle is very good pressure.
(07-11-2016 )Wiseman Wrote:  35 psi at operating temperature at idle is very good pressure.
Sorry, the 35 psi is while I'm going down the road.
Then you need to bump it up . Read Hammerhead's post and few other's related .
