Fuel timing soilenoid
05-12-2020, (Subject: Fuel timing soilenoid )
I have an isx and at idle it keeps hunting the truck has no lost power but it doesn’t idle smooth I think it’s fuel soilenoid Can anybody help me
RE: Fuel timing soilenoid
year/make/model type of engine and truck? -- Is it deleted?-- or stock w all emissions? -- When is the last time the engine was gone through and intake and exhaust sensors replaced, manifolds cleaned, etc.etc.etc.
some detailed history, mileage, and what service work has been done so far?
Since you mentioned 'actuators'... I can only assume you mean an ISX that is not common rail?.. if that is the case, did anyone bother to first do an overhead valve adjustment + set all injectors to 8 N_m (71 in/lbs), followed by an injector leak test? ...
