2006 ISX CM870 High Pyro, surging under load
06-24-2022, (Subject: 2006 ISX CM870 High Pyro, surging under load )
Post: #37
RE: 2006 ISX CM870 High Pyro, surging under load
Also having another problem the turbo is making a annoying noise when u let off the accelerator. Like turbo flutter, My old one did this also. What could cause this and any possible fixes? Let me know thanks
06-25-2022, (Subject: 2006 ISX CM870 High Pyro, surging under load )
Post: #38
if the engine has a bad de-mandate program in it then it may cause the turbo to do things it is not supposed to.
Post: #39
(06-25-2022 )Rawze Wrote:  if the engine has a bad de-mandate program in it then it may cause the turbo to do things it is not supposed to.
True,i still have not removed the de mandate i have right now, any recommendations to NJ isx people that know what they are doing?
07-23-2022, (Subject: 2006 ISX CM870 High Pyro, surging under load )
Post: #40
Quick question, is the turbo actuator arm suppose to move up and down even just sitting and revving the engine? Or always suppose to be in down position when warmed up?
Post: #41
Im doing everything to try to figure out why this turbo rattles when letting off the throttle
