| Clock spring behind smart wheel?? |
| 06-26-2020, (Subject: Clock spring behind smart wheel?? ) Post: #1 | |||
| Clock spring behind smart wheel?? This is the second time I have to replace the clock spring behind smart wheel on my 2011 kw t660. Is there a way to cancel it out and put my engine brake switches on the dashboard? If anyone has done this can you please help. Thanks | |||
| 06-26-2020, (Subject: Clock spring behind smart wheel?? ) Post: #2 | |||
| RE: Clock spring behind smart wheel?? I can not see why not, there are wires coming from somewhere, find those and install a switch. | |||
| 06-26-2020, (Subject: Clock spring behind smart wheel?? ) Post: #3 | |||
| RE: Clock spring behind smart wheel?? That's what I was thinking. Gonna have to trace those wires | |||
| 06-27-2020, (Subject: Clock spring behind smart wheel?? ) Post: #4 | |||
| RE: Clock spring behind smart wheel?? There might not be that many wires most smart wheels work off 1-2 wires each button on the wheel sends different voltages to do it's task like engine brake on being 1.5v off being 3v light cutoffs .5 or 1v this is how most radio controls work. User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 06-27-2020, (Subject: Clock spring behind smart wheel?? ) Post: #5 | |||
| RE: Clock spring behind smart wheel?? And some of these smart wheels are now using BT to communicate... | |||
