| Wet exhaust manifold |
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #1 | |||
| Wet exhaust manifold I’ve got a cm2250 @m*m^2 delete with 798k I’ve noticed in the last couple days I’ve been smelling a slight burning smell (oily) that’s more noticeable when pulling grades I’ve also noticed a little smoke from under the hood Truck seemed to be a little down on power when I was on my way home fully loaded the last 10 miles or so Friday night Yesterday on the 4th I went under the hood to check my cac and noticed my exhaust manifold is wet around cylinder 5 Also the egr cooler is wet around the rear coolant port (also oily) and there’s a puddle on the floor Also oily The hot side of the turbo doesn’t show any wetness just soot recent work to the truck include Reman turbo new manifold gaskets egr cooler seals etc And a new cyl 6 injector I installed a week ago The truck doesn’t have any noticeable smoke out the exhaust except for right after I changed the injector it smoked until it was warm And no crazy blowby our the oil cap | |||
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #2 | |||
| RE: Wet exhaust manifold The oil seems like it’s coming from above as my egt probe seems to have oil on it But nothing above looks wet | |||
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #3 | |||
| RE: Wet exhaust manifold Sounds like a bad head/valve... Getting close to in frame time with that mileage... How long has it been deleted? Carbon may have gotten it. Who did the delete, as there is no m#m$ for the 2250? | |||
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #4 | |||
| RE: Wet exhaust manifold Valve cover gasket? Oil coming out of the exhaust would show at the gaskets slip joints and post turbo and it wouldn't be a little bit either.. | |||
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #5 | |||
RE: Wet exhaust manifold (07-05-2020 )Waterloo Wrote: Sounds like a bad head/valve... Getting close to in frame time with that mileage... How long has it been deleted? Carbon may have gotten it. Who did the delete, as there is no m#m$ for the 2250? I ran 70k on a bad delete and the well known guys in Ga retuned it about 8k miles ago | |||
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #6 | |||
| RE: Wet exhaust manifold | |||
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #7 | |||
| RE: Wet exhaust manifold 720k mandated Carboned everything up 70k with a bad delete isn't healthy at all. Probly engine becoming uncarboned and going to start using oil User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #8 | |||
| RE: Wet exhaust manifold Check the valve cover gasket and when you are in there run the overhead if that has not been done. Not going to hurt... | |||
| 07-05-2020, (Subject: Wet exhaust manifold ) Post: #9 | |||
RE: Wet exhaust manifold (07-05-2020 )Waterloo Wrote: Check the valve cover gasket and when you are in there run the overhead if that has not been done. Not going to hurt... My dampener pulley is so rusty I can’t even make out the marks on it Can I run an overhead without reading the dampener I paid someone to do it a while ago but who knows if it was done right now that I think about it | |||
