Cm2350 fuel pump rebuild |
07-31-2020, (Subject: Cm2350 fuel pump rebuild ) Post: #1 | |||
Cm2350 fuel pump rebuild For those who are debating rebuilding their fuel pump here is the cost comparison. Oil change at speedco 370 bucks Fuel pump rebuild 2-3hrs labor - free done myself 2 barrel plungers - 138 - c5406130 2 tappets - 218$ - c4359134 1 head gasket h 22$ - c2872513 2 washer seals for b&ps - 7$ - c4954944 Bout 10-20 bucks more then an oil change at that price I'll probably be doing mine every 150-200k if I feel like it. Better than risking 35k for a engine Other than fuel lines on head all I had to do was take my oil filler neck off to get head in and out of engine bay on a 2016 t680 User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
07-31-2020, (Subject: Cm2350 fuel pump rebuild ) Post: #2 | |||
RE: Cm2350 fuel pump rebuild (07-31-2020 )Lonestar10 Wrote: Other than fuel lines on head all I had to do was take my oil filler neck off to get head in and out of engine bay on a 2016 t680 cheater! When I did mine I didn't know the fill tube came off so easily. So I had to carefully ease it out, even more fun with the power steering reservoir mounted to the frame in that location. Actually the hardest part for me was figuring out how to get the fuel line disconnected. After that the rest was a breeze. Just make sure you have a good vise to hold the head while torquing the barrels. Yes, the cost of parts and the simple labor are nothing compared to the continued existence of your engine. I think 350-400k between changes, maybe crack it open every 100k or yearly just to see how it looks. User's Signature: "...And as we wind on down the road, Our Shadows taller than our Soul..." | |||
09-24-2020, (Subject: Cm2350 fuel pump rebuild ) Post: #3 | |||
RE: Cm2350 fuel pump rebuild I hope u can find parts. I have one sitting in my shop now. Can not locate a pump head or rebuild parts for this specific one. | |||
09-24-2020, (Subject: Cm2350 fuel pump rebuild ) Post: #4 | |||
RE: Cm2350 fuel pump rebuild (09-24-2020 )Smooth Wrote: I hope u can find parts. I have one sitting in my shop now. Can not locate a pump head or rebuild parts for this specific one. you might have to update the whole pump. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
