Low mileage 2011 f750 Cummins 6.7
08-07-2020, (Subject: Low mileage 2011 f750 Cummins 6.7 )
RE: Low mileage 2011 f750 Cummins 6.7
Any pictures which would help?
Off the quickserve my info is the following:
Service model name
Isb 6.7 cm2250
Ecm code
Bz90018
Fuel pump
4983416
CPL3072
That tell ya anything?
quick google search shows it's a completely different style pump then the 15L ISX. Not positive, but based on the images it looks like a rotary pump. You'll need to do some more research to see if that particular pump had any issues, but I highly doubt it has the same problem as the ISX.
If I'm wrong I'm sure someone else will correct me.
User's Signature: "So long and thanks for all the fish"
08-10-2020, (Subject: Low mileage 2011 f750 Cummins 6.7 )
It's a Bosch CP3 pump, rotary cam with plungers. It is better than the X but still likes clean fuel with low inlet restriction.
Check the air cleaner and piping, I've seen a few dusted from issues with the hoses and clamps.
I'll 3rd the tune up and normal maintenance it'll be a good truck.
 Thanks given by: Rawze , JimT
08-12-2020, (Subject: Low mileage 2011 f750 Cummins 6.7 )
Thanks for all the suggestions. DEF Filter changed yesterday, its on stands awaiting new tires. Will look down the intake pipe, grease everything i can find and do a good underbody inspection.
question for you guys. the EGR valve is painted green, over the red stock paint. wondering if that means it was serviced or a reman?
Usually they are green under the red paint
maybe i got it backwards? I'll stick a fingernail on it and pick away, see whcih ones on top.
PS, that had to be the quickest response in history -- my pc didn't even show my comment was posted, and yours was already here.
Same question though. does that mean it has been serviced/reman?
No, the new ones that come on the engine from the factory are green.
08-14-2020, (Subject: Low mileage 2011 f750 Cummins 6.7 )
Stumbled upon this article about fuel pumps and thought it might benefit this discussion.
http://www.trucktrend.com/how-to/engine/...p4-failure
The long and short of it is the cp4 pump is just like the newer pumps in the cm2250/2350/x15 and in pickups fails around the 100,000 mi mark. The cp3 is a different design, not prone to these failures, and was used on cummins pickup engines up until 2018 or 2019.
08-17-2020, (Subject: Low mileage 2011 f750 Cummins 6.7 )
Thanks for the fuel pump read
Wanted to throw another question to the knowledge here.
Got a 3574 code. Low def pressure.
Ran the leak test, and I get over 130psi.
How can that be? Does it take too long to build the pressure? A sensor bad?
Just got tires on it. Gotta start troubleshooting this code.
Will do some reading tomorrow, but thought I'd throw it out there.
Have a good night,
J
