Fault Code: 1145
10-03-2020, (Subject: Fault Code: 1145 )
Post: #28
RE: Fault Code: 1145
It was definitely a good read Rawze, I totally agree with you on new and reman injectors. I had some issues with the rebuilds myself not even mentioning a friend's horror story with N14 reman injectors from a dealer.
I do admit that I have no experience with cm2350 injectors being rebuild after all I just got my first cm2350 just few weeks ago. I got familiar with an ISX engines in the last couple of years when I began to follow you on YouTube and now on here. There isn't more honest and real forum than what you created and for that I'm very thankful.
As far as OP's injector "issue", I meant that he could use quality rebuilt shop to at least check the basic parameters. I know of a good shop in my area (Chicago suburbs) that I used in past for Maxxforce injector rebuilds. I thought he could replicate my experience but I myself still am learning the curve.
