| 2250 fuel knock |
| 09-03-2020, (Subject: 2250 fuel knock ) Post: #1 | |||
| 2250 fuel knock Why would a fresh rebuild fuel knock and smoke under heavy throttle with no codes | |||
| 09-03-2020, (Subject: 2250 fuel knock ) Post: #2 | |||
RE: 2250 fuel knock (09-03-2020 )Rueale Wrote: Why would a fresh rebuild fuel knock and smoke under heavy throttle with no codes possibly ... * cam slip?. Wrong wedge used? * fails leak-down test?. * boost or exhaust leak? * turbo acting up or out of calibration? * incorrect overhead valve adjustments? * water or coolant in fuel? * burning too much oil b'cause some rings did not get aligned correctly?. * wrong injectors in wrong holes and no longer match injector trim codes? * wrong inframe kit? * Loosing compression due to bad head? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
