Where to buy cummins insite? |
07-22-2016, (Subject: Where to buy cummins insite? ) Post: #1 | |||
Where to buy cummins insite? Hey guys I'm new to cummins engines and wanted to purchase cummins insite, where can I buy it and what else do I need? What type of laptop is needed as well? I have a 2011 cm2250. Thanks | |||
07-22-2016, (Subject: Where to buy cummins insite? ) Post: #2 | |||
RE: Where to buy cummins insite? P.M sent User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
07-22-2016, (Subject: Where to buy cummins insite? ) Post: #3 | |||
RE: Where to buy cummins insite? Ebay. Hong Kong. | |||
10-07-2016, (Subject: Where to buy cummins insite? ) Post: #4 | |||
RE: Where to buy cummins insite? I am also looking for insite. I'm about to purchase a 2014 Volvo 730 with a Cummings 485 HP. Any info in truck or motor would be appreciated. | |||
10-07-2016, (Subject: Where to buy cummins insite? ) Post: #5 | |||
RE: Where to buy cummins insite? (10-07-2016 )Merritt Wrote: I am also looking for insite. I'm about to purchase a 2014 Volvo 730 with a Cummings 485 HP. Any info in truck or motor would be appreciated. The best advise I can give you, you may not like to hear... If you are thinking of buying a used truck, you need access to Insite BEFORE you purchase. You need Insite to see and obtain an ECM download to look at; -any active fault codes -any inactive fault codes -engine abuse history -regen history You MUST remove the rocker cover and inspect the cam and rocker assembly. ISX's are notorious for cam and rocker issues. Poor oil service intervals exasperate these issues, and only a visual inspection can help you avoid a potential catastrophe. I remove my rocker cover routinely to inspect for wear patterns. Then you go over the unit with your coveralls on, flashlight, pen and notebook in hand and perform the equivelant of an annual inspection taking notes of everything You should pull oil samples, if the unit appears satisfactory, from the engine, tranny, and both diff (APU as well if equipped) and get them analyzed by a good lab. Overnight them if you have to. Post those results here, along with pictures and notes you have made, IF you want an honest Assesment of the unit. A while back a guy purchased a used truck from the Atalanta area and brought it by for Rawze to look over. If you would have seen that video, you would be terrified and you would take this small snipe of advise, then go read Rawze's book about how to inspect and make an informed decision... Good luck, and don't be scared to share what you find. You may not like what some of us will tell you, but it will be a brutally honest Assessment. Not to piss you off, but to help you avoid the pain of avoidable issues. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
10-07-2016, (Subject: Where to buy cummins insite? ) Post: #6 | |||
10-07-2016, (Subject: Where to buy cummins insite? ) Post: #7 | |||
RE: Where to buy cummins insite? (10-07-2016 )Merritt Wrote: I am also looking for insite. I'm about to purchase a 2014 Volvo 730 with a Cummings 485 HP. Any info in truck or motor would be appreciated. Waterloo answered above, eBay, Chinese knock off... Buy yourself a Windows 7 computer....you can even get a used one and take it to Staples and have the hard dive wiped and fresh, if your not real computer savvy...so it's not infected with any viruses. When your Inline adapter arrives, ask for help. There are members here who will remotely install and set it up all nice... When your done, remember this computer is a TOOL not a toy. No internet surfing, no space book, and even no Rawze.com. It should be dedicated to Insite and your Truck ONLY!!! That will keep the HIV/AIDS, and other viruses at bay from your ECM so no porn surfing either...lol User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
10-08-2016, (Subject: Where to buy cummins insite? ) Post: #8 | |||
RE: Where to buy cummins insite? (10-07-2016 )Hammerhead Wrote:(10-07-2016 )Merritt Wrote: I am also looking for insite. I'm about to purchase a 2014 Volvo 730 with a Cummings 485 HP. Any info in truck or motor would be appreciated. But -- What if i WANT my ECM to porn-surf? -- I like my truck to be happy too.... J.K> Hammerhead is right. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
10-08-2016, (Subject: Where to buy cummins insite? ) Post: #9 | |||
RE: Where to buy cummins insite? Listen to these guys, they know what they are talking about. Don't make the same mistake that I did. I got lucky on the cams but within the almost 2 years that I have owned this truck just about every part of the emmisions has had the be replaced. knowing now what to look for I would have spent a whole day or better checking this money pit out. User's Signature: I don't know sh!t from shinola! | |||
