Replace the transfer fuel pump.
08-04-2016, (Subject: Replace the transfer fuel pump. )
Post: #55
RE: Replace the transfer fuel pump.
./uploads/201608/post_1749_1470326476_634454af418f0bb842ee8601b5aed19b.jpeg
Post: #56
So far ceramic on oil pan but looks like no metal shavings, only damage is the fuel pump cam and rolers, valve cam and rolers look clean, it was dark when I took the valve cover i will mess with it some more if I get home this weekend Godwilling
Post: #57
(08-04-2016 )jimeneztrans84 Wrote:
(08-03-2016 )sbtrucking Wrote:  What is the upgraded fuel pump with steel plungers part # ?
4307527 new part number for 2 cylinder pump. If you have a 2012 you should have a 2 cylinder pump just update you plungers and tappets.
I will call around with this ^part #,
I wasted hours calling dealers around with the engine serial #, and they kept giving me different part #s, i got happy found one for $2100 but they gave me part # 2872662px
So I guess its the wrong part?
Post: #58
./uploads/201608/post_1749_1470327885_accec39de01b23c791cb265ef12bdd22.jpeg
Post: #59
After several phone cals and online searches found out that the part #4307527 superseded to #4359487
And this site is the cheapest I found, before I order is this reputable company?
http://www.bigrigworld.com/pumpfuel.html
Post: #60
You need fuel lines also
Post: #61
(08-04-2016 )jimeneztrans84 Wrote:  You need fuel lines also
I already have the 2 piston pump, do I still need fuel lines?
Post: #62
Yes just the 2 back ones.
Post: #63
(08-04-2016 )jimeneztrans84 Wrote:  Yes just the 2 back ones.
Do you have part #'s for the 2 back ones?
