New code
10-13-2020, (Subject: New code )
New code
I’m getting this code engine intake manifold #1 pressure voltage below normal, or shorted to low source
SPN:102
FMI:4
The diagnostics that my truck has is saying boost pressure
Any idea.
Thanks
2013 w900L
Isx15 550
./uploads/202010/post_5153_1602625537_060892adecf73cd62f8aa5b2a38bab73.jpeg
RE: New code
bad IMAP sensor or not plugged in all the way?
 Thanks given by: JAsaro , redbeard
10-14-2020, (Subject: New code )
RE: New code
That fault (123) is almost always a failed IMAP sensor. Worth changing regardless if you don't remember doing it in the last couple of years.
 Thanks given by: redbeard
