Rebuilding Detroit
11-09-2020, (Subject: Rebuilding Detroit )
Rebuilding Detroit
Ok am rebuilding my 2007 Detroit series 60 14l truck has been mandated at 500,000 it now has a little under a million ... the man date was done by a guy up here near Connecticut I feel it was done right bc for 4 years I haven’t had one check engine light on and absolutely not one thing has gone wrong with the motor I can’t believe it ... well anyway the truck is in the shop getting a total rebuild motor out of truck bc at that miles why play games am getting the bull gear done new head , new oil pump , oil cooler water pump oh and a rebuilt transmission bc I got a great deal on it so while it’s out why not just get it over with and save on the labor ... is there anything else you guys can think of that I should have done while it is out ??? They will check the injectors to see how they look.. also after views this site am starting to think I might be putting my truck back to stock bc everyone keeps talking about having two guys do the tune and am not sure if one of them is the guy who did mine bc they use nicknames
11-10-2020, (Subject: Rebuilding Detroit )
RE: Rebuilding Detroit
(11-09-2020 )Jimmy3308 Wrote:  ...has been mandated at 500,000
...getting a total rebuild motor
For a Detroit, have the programming looked at by Mommaburt on here or take it to Gearheads shop (Price's Diesel in Oxford, PA).
- Don't trust that casual attitude of "it Seems to run ok". - A person should confirm and Know exactly what someone did by sending their program to me (I review cummins programming) or one of the couple people mentioned on here that can tell you without bias as to exactly what you have. Until then, you should assume it is bad now that you are aware of how big of a plague that bad delete programming is in our industry.
This plague of bad deletes is just as bad with detroits as it is with cummins. Detroits are a bit more resilient than red engines with regards to bad delete programming due to top-stop liners being less sensitive to excess friction based on bad programming. Make no mistake about it though .. bad programming does shorten their life. How much so also always depends all on how hard its driven too. - Best thing is to avoid it all together and not make kind of assumptions about what you have in your ecm based solely on "seems to run good"... because about 7 of every 10 people that find this forum who have red engines that clearly had horrible programming also assumed the same thing at first.
- Most Detroits that have typical bad deletes are usually stuck permanently in "high altitude" or sometimes "exhaust warm-up" operating modes. Some over-boost all the time and some do not, but they all run way too lean when they are set this way and create a lot of internal friction. Some people also will report that their radiator temps climb more easily after their delete than before and this is a sign of something wrong as well ... depends on how bad the programming really was.
Detroits, like cats, do not have mid-stop liners. This results in the problems with excess internal friction by bad programming baing not quite as damaging like it is for cummins. Some see the Detroits as overall more resilient to this kind of abuse, but this is by no means an excuse to use and allow harmful programming. Some brands of engines do not show bad programming as easily as others, but they all have their strengths and weaknesses. Any programming that is harmful will indeed shorten engine life (or engine component life) in one way or another.
== As far as someone proclaiming they are good at this type of work goes, it helps to be able to ask the right questions...
These days, if anyone even near worth their salt with regards to custom engine tuning cannot answer clearly and precisely, and what i would ask them to show and explain to me ...
* What engine operating mode(or modes) the engine is going to run in and what modes got disabled?
* What turbo A/R ratio range the turbo should be running after their tuning was done?
* What are the acceptable injection timing ranges should be expected at what rpm and fuelling rates for this model and displacement engine? .. What are they now going to be set to now that there is no more EGR gas?
* What secondary (fall-back) or other emissions controls internal to the engine programming will still be left active?
* What is the new Fuel-Air-Mix for the engine going to be re-programmed into the enigne now that EGR gas is missing?
+++ I would likely ask dozen other "VERY EASILY ANSWERED AND STRAIGHT FORWARD CONCERNS THAT SOMEONE WOULD HAVE" about their engine.
- Are they also willing to give or e-mail a copy of the program they are about to put in your truck so that it can be restored and that you are not reliant on them if anything ever happens to the ecm?. This is a huge mistake that most all truck owners make, and i get hundreds of phone calls a year where a truck owner lost their ecm and now the "guy who deleted it" wants another several thousands to do it all over again. It is bad enough that an ecm might cost you a couple thou$$sand dollars, but then some dick#[email protected] wants another few thousands more to program it because it was "deleted".. that or even worse, it has been several years and the person is nowhere to be found. You have backups of your photos and other important business documents, ... why not your custom and unique ECM programming that is hard to replace?
-- Trouble is that all these clowns that do this type "delete" programming are experts in making the lights go away off the dash of the truck or car .... they all claim they know what they are doing ... but it clearly points towards none of them understanding what the he#ll is going on inside that engine enough to properly correct things once that EGR gas is taken away. Some have figured out how to force the ecm in various ill-begotten ways to make more power by tweaking fuel or torque settings, but beyond that, this is where the extent of what they know stops dead in its tracks.
I call it "jail-breaking" the ecm .. but it has no regard towards the health of longevity of the engine itself. I think that these people all too quickly forget that it is not the ecm programming alone that makes you your living, it is that engine ... and that engine is the most important thing to understand, yet this is where they all fail.
- whenever I review someone's cummins ecm programming, I look at proper engine mode control re-mapping, what corrections to injection timing have been made, what corrections to fuel-air-mix have been made, what corrections to turbo boost control have been made, how the engines fall-back emissions control that try to take over when egr gas is missing have been handled, what power or torque changes that someone has made, and if there is any places in the ecm where they are destroying trim data or other balancing estimations because they tweaked fuel quantity or other settings in attempts to fool the ecm into giving up more fuel than it is supposed to against its will. - Those are the first things I look for when reviewing someones programming and also where the biggest mistakes are made. i then verify that the settings in the ecm also match the make/model truck and components of the engine. This is just as important because a lot of these delete guys ignore this completely as well.
- You know your in trouble as soon as you start asking one of these tuning guys some of the basic questions about necessary corrections and how they are going to be adjusted in your engine (the things I mentioned above) and they are quick to respond with "we left that factory" and "we let the ecm figure it out" and they tell you things like "that is our secret" and all the other excuses they can come up with to avoid answering any of these basics about the engine because they have no absolute clue themselves, and then resort to getting defensive and sometimes even downright mad and mean all due to the fact that they do not want you to know that they themselves are completely clueless!.
Sad part is that I don't fault these guys who are doing this type of work for being clueless... I fault them for charging, usually, thousands of $$$$ to their victims for terrible programming and then getting arrogant and defensive about "how smart they are" instead of taking steps to genuinely improve and correct what they are doing when someone attempts to show them the errors in it. I have met very few people who give a damn past that quick $$$ to slap a program in your ecm that they themselves mostly have no clue what it is about to do outside of making some emissions lights disappear and the engine seem to do somewhat ok. This is quick and easy money for them and is the heart of the entire plague of bad deletes. It is why it is so rampit, plaguing our industry. Combine this with truck owners who are desperate to rid themselves of the constant problems those system present, this creates a widespread opportunity for every shop to make money off every 3rd person who walks into the doors.
Thank you for all that info greatly appreciated... I’ll have to call the guy and see what he has to say about your questions you said to ask ... what I do know it that the temps stay at 175 for the most part and even during the summer claiming big hills the temps don’t go high enough to even turn the fan on ... the egt temp never go pass 900 and that’s on a big pull ... is there anything else you would change while the motor is out ?
11-12-2020, (Subject: Rebuilding Detroit )
Change the fuel pressure regulator / check valve on the back of the head. It isn't exactly a cheap little part but I should 100% be done if you haven't, have them manually test fuel pressure after to see if the pump should be done as well.
The valve on the back of the head is not to be confused with the check valve everyone talks about online, they are almost always referring to the ddec iv engines which are only a check valve, on the ddec v it is also a pressure regulator.
Mommaburt can tune that thing absolutely beautifully for a very good price, I'm not sure how often he's on here anymore but Rawze or myself could get you a contact info if you message either if Interested.
I agree with Rawze, alot of the Detroit 60 tunes are butcher jobs, not saying yours is though.
Thanks a lot does this motor also have a check valve that everyone says to replace or is this I place of it ? Also when you say not cheap around how much you think it is. Thank you for your help
11-13-2020, (Subject: Rebuilding Detroit )
That check valve is the one I'm referring to, guys will just spit out knowledge they hear on the interweb without actually knowing what they are talking about.
The check valve they are referring to is a pressure regulator on the ddec v and a check valve. It's only a check valve on the older ddec which is why so may guys don't take that regulator into account when diagnosing low fuel pressure on the ddec v.
Also the bull gear, everyone on the net will tell you its such a big failure point, that's not true on the ddec v but guys online don't realize that because ddec iv is the commonly talked about engines and we all just pretty much regurgitate info we've read online.
