Coolant leaks when it's really cold |
12-15-2020, (Subject: Coolant leaks when it's really cold ) Post: #1 | |||
Coolant leaks when it's really cold Do any of you have issues with coolant leaks on a truck that sits at 0F and below. Both my CM570 and CM870 leak from the water pump o-ring when it gets really cold. We've replaced o-rings several times to no real success. Lubed with lubriplate grease always and always using OEM Cummins o-rings. Does anyone have a magic cure other than park the trucks inside? | |||
12-15-2020, (Subject: Coolant leaks when it's really cold ) Post: #2 | |||
RE: Coolant leaks when it's really cold my 870 would leak when really cold outside too. Didn't leak much so I never did anything about it did. Just enough to make a small puddle. User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
12-15-2020, (Subject: Coolant leaks when it's really cold ) Post: #3 | |||
RE: Coolant leaks when it's really cold The water pump housing isn't starting to get grooves or any signs of wear right? While I've never had this happen, Cummins does say that use of petroleum based lubricants will cause the oring to swell and leak. All the products lubriplate makes are petroleum based that I've ever used. You might try it again a silicon based non petroleum grease. I like Sil glyde. It's made by AGS but Napa rebrands it and sells it under their name as well, but anything non petroleum lubricant would work. | |||
12-15-2020, (Subject: Coolant leaks when it's really cold ) Post: #4 | |||
RE: Coolant leaks when it's really cold check your coolant/water ratio, could be too much water causing o-ring to fail due to expansion. | |||
12-15-2020, (Subject: Coolant leaks when it's really cold ) Post: #5 | |||
RE: Coolant leaks when it's really cold Might want to check and see if their has been an update to a different oring This happened to me before User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
12-15-2020, (Subject: Coolant leaks when it's really cold ) Post: #6 | |||
RE: Coolant leaks when it's really cold I always coat the o-ring in thin layer of anti-sieze when installing. Have not had one leak. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
12-16-2020, (Subject: Coolant leaks when it's really cold ) Post: #7 | |||
RE: Coolant leaks when it's really cold The 570s always leak from the plastic cover on the back side. There's a repair kit for them but worth replacing the whole pump if it's a few years old. | |||
12-17-2020, (Subject: Coolant leaks when it's really cold ) Post: #8 | |||
RE: Coolant leaks when it's really cold (12-15-2020 )Rawze Wrote: I always coat the o-ring in thin layer of anti-sieze when installing. Have not had one leak. I'll second the anti-seize. Used that exclusively on all the o-rings and gaskets during my engine rebuild (except injectors) and have had zero leaks from any of those locations. User's Signature: "...And as we wind on down the road, Our Shadows taller than our Soul..." | |||
12-17-2020, (Subject: Coolant leaks when it's really cold ) Post: #9 | |||
RE: Coolant leaks when it's really cold Thanks for the advice. We'll try that anti-sieze idea. Can't hurt. Will look at that plastic cover as well. | |||
