2350 boost pressure while engine braking.
12-17-2020, (Subject: 2350 boost pressure while engine braking. )
Curious what guys are seeing for max boost pressure under higher RPM engine braking(1800-1900) on cm 2250/2350s. I have seen mine get as high as 40 psi briefly while using the jake.
User's Signature: 2015 389 Peterbilt. ISX 550 18speed 3.70 gears
RE: 2350 boost pressure while engine braking.
40 psi sounds excessive. Many ISX's will crest at about about 28~ish psi under full load on highest setting.
 Thanks given by: SemiSweet
About 35 psi when braking. 32-33 psi boost full throttle.
12-18-2020, (Subject: 2350 boost pressure while engine braking. )
450hp 2350 about the 28 psi mark.
My cm870 would hit 33psi at absolute peak and my cm871 hits 28-29psi.
