CUMMINS SWAP 2250 to 2350.
01-10-2021, (Subject: CUMMINS SWAP 2250 to 2350. )
RE: CUMMINS SWAP 2250 to 2350.
(01-02-2021 )ESDrepair Wrote:  so i took out a 2012 isx esn: 79574017 3 plug ecm had a spun bearing
I was sent the program from this truck today (the 2250 engine that failed). Another bad delete.
the program is almost identical to this bad delete mentioned here...
http://rawze.com/forums/showthread.php?t...4#pid46124
 Thanks given by: redbeard
(01-03-2021 )SquareOne Wrote:  I can def attest to the procedure Rawze is referring. I currently have nearly 180k on the setup he tweaked in Feb/March of 2019. ----> 2250 modded ecm program running a 2350 engine. Very interesting the details that make those 2 engine types differ and like he mentioned before, most would never know as the 2250 ecm would initailly appear to run the 2350 with no issues.
Talked to them on the phone. Seem like some nice ppl.
they decided to put the 2250 ecm and wiring harness back on the truck, start over with it, and have that original ecm run the 2350 block and hardware.
I had them flash the old ecm back to stock programming (it had a bad delete in it /mentioned above ) and start over with a clean program.
They sent me the program and i set it to run that 2350 block, cam, turbo, injectors, compression ratio, fuel-air-mix, exhaust manifold,..etc.etc.etc. for the 2350 based on its ser# and hardware. Hopefully this will fix them up, and hopefully there is nothing wrong with that used engine, as it has 250k miles on it or so and may have had a delete program in it as well?-- unsure what harm it may have had done to it by the last owner. maybe they will have good luck with it, at least the programming should now be ok for it.
 Thanks given by: redbeard , SquareOne
01-17-2021, (Subject: CUMMINS SWAP 2250 to 2350. )
Rawze is the man trust what he says he has a lot of knowledge did what he said to do with running the 2250 ecm on a 2350 motor and had Rawze sent me a program for it and it’s running amazing.
Thanks Rawze you the man bro !!!!!
 Thanks given by: Rawze , redbeard
(01-17-2021 )ESDrepair Wrote:  Rawze is the man trust what he says he has a lot of knowledge did what he said to do with running the 2250 ecm on a 2350 motor and had Rawze sent me a program for it and it’s running amazing.
There have been several others on here that ended up in this same situation with no solution in the past. I just try to help others as best I can, noting more.
Thanks for the follow up .. was curious how it turned out for ya, as i had not heard anything back.
 Thanks given by: SquareOne , amermextrucker , redbeard
