Truck abs light came on when heavy loaded
01-19-2021, (Subject: Truck abs light came on when heavy loaded )
Hello,
2013 cascadia cummins 2250, for some reason i get truck abs light when heavy loaded . usually it turns on after my first turn out of loading dock. any one experience this before thank you very much.
RE: Truck abs light came on when heavy loaded
When is the last time someone re-torqued all the hub bearings? ... It is supposed to be done every 250k miles.
01-20-2021, (Subject: Truck abs light came on when heavy loaded )
(01-19-2021 )Rawze Wrote:  When is the last time someone re-torqued all the hub bearings? ... It is supposed to be done every 250k miles.
Will do thx rawze
