T660 pressure test radiator cap??
08-04-2016, (Subject: T660 pressure test radiator cap?? )
I'm looking to pressure test my 2011 t660 with isx motor buto idk where I can buy a radiator cap to hook up the pressure pump. Anyone know where I can buy one?
RE: T660 pressure test radiator cap??
The t660 has the plastic screw on cap or the old metal twist lock?
Plastic screw cap
This is what I use. I made it myself. Cheaper than buying it with parts I had laying around. Lol
./uploads/201608/post_132_1470340770_fcf63254a70bc53be0a86f23667d6a3d.jpg
I bought the pressure test kit at Harbor Freight, and it worked on my t660.
(08-04-2016 )hhow55 Wrote:  I bought the pressure test kit at Harbor Freight, and it worked on my t660.
Do you have a part # or they only sell one?
Pittsburgh Automotive 69258 Radiator Pressure Tester Kit
Item #69258
Awesome thanks!!!
