Iron high in sample |
04-01-2021, (Subject: Iron high in sample ) Post: #10 | |||
RE: Iron high in sample (03-31-2021 )hookliftpete Wrote: If the damper was going south, would it cause the crankshaft to wear badly that quickly? I would think it would be very noticeably shaking while running for this to be a problem. Maybe you should take a look inside your high and low pressure fuel pump. Maybe just replace the low pressure if it's original. User's Signature: Warranty??? Yeah right, I am the warranty!!! | |||
04-01-2021, (Subject: Iron high in sample ) Post: #11 | |||
RE: Iron high in sample Both high and low pressure pumps were replaced last year, but I will look anyway. Its the easiest place to start. | |||
04-09-2021, (Subject: Iron high in sample ) Post: #12 | |||
RE: Iron high in sample Which engine? Also are you using max milage from {piss-poor-power}? My iron came back at 42 last oil sample. Was told the {piss-poor-power} stuff could cause that | |||
04-09-2021, (Subject: Iron high in sample ) Post: #13 | |||
RE: Iron high in sample This is an isc, no pttsburgh anything on or in there, just stock tune by Mr Hagg. This is a pushrod. | |||
