Factory new air compressor!!
03-19-2021, (Subject: Factory new air compressor!! )
RE: Factory new air compressor!!
Was the Piston on the old style compressor at TDC when the X was aligned with the notch?
03-20-2021, (Subject: Factory new air compressor!! )
Well, I couldn’t come with a way to time the new compressor so I just installed it per quick serve. I crank it up and it seems smooth and quiet. I either lucked out or Cummins was right and it really didn’t need to be timed.
 Thanks given by: hhow55 , JimT , Waterloo
03-21-2021, (Subject: Factory new air compressor!! )
lucky. my compressor has been a loud rackety annoyance since it was replaced 2 years ago. maybe they learned/fixed something since then... or more likely you just got lucky
edit: I have a cm2250
User's Signature: Think for yourself. Question authority.
 Thanks given by: JMBT
03-22-2021, (Subject: Factory new air compressor!! )
Strange. I replaced mine a couple years or so back. It's marked.
User's Signature: 2010 T2000, CM871, 13spd, 900k, tanker yanker
This one was not. I thought I was crazy but Mr Hagg confirmed the new ones are not marked and QuickServe says they do not need to be timed to the engine.
I replaced my air compressor on my 2250 and it too was NOT marked with an X.
