Quickserve navigation |
03-21-2021, (Subject: Quickserve navigation ) Post: #1 | |||
Quickserve navigation In which section do I find the part numbers for the IMAP, Delta P, and that other sensor for the EGR tune? | |||
03-21-2021, (Subject: Quickserve navigation ) Post: #2 | |||
RE: Quickserve navigation Click option view. Some of the sensors will be under electronic control module, some will be under exhaust gas recirculation. | |||
03-22-2021, (Subject: Quickserve navigation ) Post: #3 | |||
RE: Quickserve navigation I found these part numbers searching the forums 4928594 pressure sensor 2897334 I map 4307166 delta for 09 Cummins engine I found the 4928594 pressure sensor searching though my engine. It’s in the exhaust gas recirculating section. Still searching to find the others before ordering parts. | |||
